Did you get anywhere with this software. I am thinking of getting a discovery 2 just to use this suite of software. Would be interested in any feedback you may have, particularly in what the range is for distortion measurements.
Yes, that part I was able to figure out. The only thing so far that I have not been able to setup is a swept frequency response over the audio range that shows distortion.
Hi Joe,
Joe in Virginia
just know the signal gen is out of #1 and you have to use a splitter/Y connector to the amp. You can use channel 1 and 2 for readings.
Thanks!
I will download it and play with it over the weekend. Hopefully all works well and I do not have any questions.
Regards - Joe in Virginia
Link to dropbox is in the description.
