Hi ! I'm testing for the first time my EAR 834 clone, following as close as possible the Skunkie's layout. I'm testing with cheap tubes : x2 12AX7 JJ and x1 Ruby 12AX7. Very satisfy with bass reponse, high, with all, wicked !!! but it's clipping RED on my vu-meter (I diy vu-meter on my ADC Sound Shaper EQ).
Could we talk about gain stage there ? Please, give me your science, advises, references etc. Just, I dont want volume pot ;)
I know tubes have differents gains. But resistors control the gain. Which value should I change for resistors ?
Thanks Everyone !
Great info
I'm really not understanding what you're trying to do cuz from you posts it appears like it sounds fine. You're just wanting to get some VU meters reading in the center or something?
Ok so i'm trying a 47k S.F.E.R pot with this RCA pannel, but i'm wondering about the output common ground, where is the best ground way on board ? on the chassis seems fine, nothing sound bad, as if pot was assembled on the chassis.
edit : this RCA pannel came from an EQ, and he provide a common ground as you can see in the photo. he going to the chassis (with those 10n ceramic caps), but thought the EQ board
Interesting fact : i don't need any EQ correction with this wonderful EAR 834 !
@Skunkie ''Upstream'' , I mean ''in the preamp'', not after. Ok how to fix this mismatch impedance problem, do you know that? Is it the use of a buffer ? This preamp will be used, sometimes, on some mixer like this Pioneer.
Should i need a stereo potentiometer 2x3 pins ? what troubles me is that there are 9 holes for soldering on the clone pcb. I have to solder all ?
Ok so it's clipping red maybe doesnt mean EAR 834 is clipping, But I need less gain. Has anyone ever tried installing a stereo potentiometer?
I tried using a latest generation Pioneer DJM-450 mixer, to benefit from its gain potentiometers. But the sound is noticeably less good, surprisingly. Distortions are clearly audible. I don't think the Pioneer is to blame. I think you need to adjust the gain in the preamp, upstream. I think...
But I don't really understand why there are 9 pads to solder the potentiometer? I don't see a 50K potentiometer (VR) on the diagram.
