I guess this explains why there are no Chinese clone amplifiers based on Bob Carver's designs: (Note: This schematic is for the 1988 'Silver Seven' that used 14 KT88 tubes and was rated at 375 watts into 8 ohms. The specs and photo are for the 2014 'Silver Seven 700' that uses 20 KT120 tubes):
Carver Silver Seven 700 Monoblock
Rated Power (8 ohms): 900 watts RMS continuous - 900 watts RMS with vocal and music
Frequency Response: 2 Hz to 85 kHz (-3 dB)
Distortion: Less than 0.5%
Power Bandwidth: 18 Hz to 28 kHz
Line Inputs: 2 (RCA); Normal (AC coupled) or Lab Direct (DC coupled)
Input impedance: 100 K ohms
Gain: 36 dB
Tube complement: One 12BY7A, one 12AL5, three 12BY7A, and twenty KT-120s
Hum and Noise: Better than 120 dB, referred to 700 watts, (A-weighted)
Bias: Rear panel potentiometer adjustment
Source Impedance: 1.7 ohms
Speaker Output Taps: 2, 4, and 8 ohms. (Designed to drive any load 0.75-ohm and higher)
Color: Deep burgundy with gloss black, natural aluminum, and bright chrome highlights
Dimensions: Amplifier Chassis: 9” (228.6mm) x 13” (330mm) x 20” (508mm) x 2 - Power Supply Chassis: 9” (228.6mm) x 11” (279.4) x 20” (508mm) x 2
Weight: Amplifier Chassis: 55 lbs. x 2 - Power Supply Chassis: 45 lbs. x 2
Warranty: Lifetime warranty including the tubes.(DC restorer circuit means that the tubes will last as long as 50 years)
Bob always did get a bit carried away..................
http://www.phaselinearhistory.stereomanuals.com/700seriesamp.htm
When these blow up it wipes out ALL the transistors.
Wow! An electric heater AND amp in one go! Nothing beats a multifunction device. And if you are a labyrinth enthusiast, you can use the schematic to build a modern version of the Minotaur's lair. Total genius, this.
Sadly, Australia and both Northern and Southern Poles are on the front row of this horrible film entitled Climate Change. And that's not a Hollywood sci-fi movie. Hang on.
Can you imagine the heating issues with this setup. Speaking of heat, how is the weather down under? If you have any difficulty ordering from Mouser or any other online store in America, let me know. It would be easy for me to order whatever you need than send it to your place.
KT88 should be at least 4 inches apart from each other. Clearly, this is not the case.
