Newbie question - You mentioned in your wrap-up that you thought the output transformers were the reason for the low wattage, and talked about scaling up to the 15 watt model and seeing if it got you a few more watts. With 10 watts potential on the output transformers, why is final output not at least a little higher? My brain wants to jump to the conclusion that if you're not getting 10 watts out of a 10 watt transformer with adequate power from the PSU the issue must be a lack of gain or something else on the input side. Or is it just general inefficiency of the tubes, etc? If it's gain would expanding the design to a parallel output tube configuration help get more out of the OTs? Or is moving up to a larger transformer the only option for more power in this particular design? It would be awesome to see 5+ Wpc. Would scaling up either the number of tubes or the wattage of the OTs be pretty straightforward or would the overall architecture of the amp need to be upgraded? Thanks!
Fixed and available
BOM uploaded, I never made one and spend several hours this morning making one for y'all. https://www.skunkiedesigns.com/6bm8-amp
I’m looking for the 6BM8 BOM as well. Anyone have one?
Oops. I meant 1615A. Clumsy fingers. I didn't realize it was a different style. Glad I asked. Thank you.
1516A? I see a 1615A but that's a push pull OT.
Thanks for this. You weren't kidding on the wait times for those Edcor OTs. They're over 3.months now. I see the Hammond 1516A is available from several places at a notably higher price but similar specs - 15w UL 5k/8ohm, 40% screen, 30-30khz, and a slightly smaller footprint. Do you have an opinion on these as an alternative?
The larger OT is to help the low end/bass response. It won't make more power. If I was going to "add tubes" I would build it as a push pull design, which would totally change everything.
Also, the BOM spreadsheet is missing on the 6BM8 project page. Would love to have a copy of that.
