The video showing replacing the resistors in the power supply shows a GREEN (wire round) resistor?) resistor. What is the VALUE of that resistor? And does it have to be a wire round resistor?
Thank you so very much. I found a very handy resistor calculate at Calculator.net. I appreciate your help.
I was wrong in that video, it's not a wire wound resistor and the value is 4.7K 2W
4.7k if it has the same markings as this image.
