While asking some questions regarding my 6LU8 build, someone posted a link to the schematic from your web site. The one I used to build my 6LU8.
Anyway, someone pointed out that in your schematic the 2.7k resistor should come AFTER the 510k resistor.
Now, I have no idea which would or would not be correct, but I went ahead and reviewd your 6BM8 schematic, and the connections from triode plate to pentode grid is different, There the 1k resistor is connected AFTER the 470k.
I also reviewed several other single ended schematics, and they all have the grid resistor right before the grid, and the large resistor to ground is BEFORE the small one.
I just would like for you or someone else who can help me here to let me know the correct way to wire this interstage.
Roger
It honestly doesn't make any difference. Just put the grid stopper close to the tube pin and if there isn't a good place to attach the grid leak resistor at the input side of that smaller grid stopper resistor, I just attach it to the grid pin which is after. These two resistors are performing different functions and the order they are in doesn't impact their fuction.
