I am getting static in one speaker at idle on my Riesong A10. I have not done any mods. I have changed some tubes.Dan
If you swap tubes side for side does the static follow one pair of tunes?
Are you seeing any flashing in the centre rectifier tube?
I have tapped all the tubes several times and it doesn't affect the static from the speaker. I am wondering if doing the Skunkie mods would fix this problem?
