Hello community ! Hello Stephe !
I'm about to finish EAR834 clone, but hesistant about the diodes on the power board. Are D1, D2, D3 and D4 the same value/reference all 4 ? I bough 1KV 1A for them : x4 1N5623GP.
Can you recommend a site where I can find all the coupling capacitors, like mundorff ? and some precision resistors (68k 3w and 2M which I forgot on Mouser....)
Here are some photos of the assembly to get your opinions ๐จโ๐จโ๐งโ๐ฆ
Some solder flux stains visible in the photos, I will clean with a special cleaner when all the components are installed... Can you explain to me some tests to carry out before powering up, with a multimeter please? I saw Stephe's video of course, who tests the power supply board fully assembled, but separated from the RIAA board. How should I carry out my tests in my case?
anti-involuntary movement switch ! you have to pull upwards then be able to activate the switch ;)
Better too much than not enough lol
short circuit?ย I hope not ! lol
I'm hesitant to use gold plated connectors to get a quick connect/disconnect of the RCA wires on the board... in case of a fault to diagnose or tweak components...
Tim, thanks for posting the closeup pictures! Nice lead bends and solder joints!
Yeah, D1-D4 are all the same. I've been buying my caps from https://www.madisoundspeakerstore.com/mundorf-mcap-evo-oil-caps/ And don't you hate it when you miss 1 or 2 parts on a mouser order? I also do this fairly regularly lol.
