Can you measure the ripple on the DC filament supply? This filament supply deviates from the original EAR834 design and may have higher ripple than originally intended (estimate 5mVAC original vs 200mVAC this design).
There is no ground from the transformer, at least not using the 200 series ones. I plan to do a video soon about why I build my EAR834 clone pre-amps the way I do. I get a lot of emails from folks who decide to change the layout for whatever reasons and have lots of problems with noise and hum. For example having the tubes exposed like you did is going to create noise. I'm honestly not sure your layout can be made to be quiet.
Ok that will be most interesting to see would u pls let me know when u do so.. i brought another board and thinking about rebuilding it more in line with urs
Hiya Just wanted to let you know I watched you video, and decided to follow the advice. Im at present rebuilding the amplifer in an enclosure like yours. So far ive drill the chassis mostly. Just need to do the power socket and on/off switch and the metal work will be finished. I brought a new board and will be transferring the parts from the old boards as I wasnt that happy with my original soldering… will update in the coming months of how I get on and if its ok…
Somehow the test ground point you are using isn't grounded to the negative or something. Tubes need hundreds of volts to operate. Can you show some pictures of the inside? And you say one channel does work?
Was wondering if anyone might be able to help im having issues out of one channel I dont get any sound. I checked solder joints they seem ok. So i did voltage checks of the tubes and seem to be getting strange figures. All measured to ground execpt pins 4 and 5 heaters which where measured to pin 9
-Thanks
Well absolute waste of time spending a lot of koney building this and all i get is hum.
Do you have your meter on DC - not AC?
0.xx voltages? And how are you mneasuring these?
Tube 1
Pin
1 - 0.83
2 - 0.21
3 - 0.21
4 5.96
5 5.94
6 0.41
7 -0.22
8 -0.21
Tube 2
Pin
0.28
-0.24
-0.23
5.93
5.94
0.20
-0.24
-0.24
Tube 3
Pin
5.90
1.92
1.81
5.95
5.94
4.20
0.68
0.68
Anyone any idea its driving me mad
