Hi everyone, I want to share my slight modification of the Skunkified Color Preamp schematics by Matt.
My general purpose was to reduce the noise levels of the original device.
I'm now finalizing a PCB using this schematics, so any comments before it goes into production.
Of course PCB will also be shared.
Hi everyone!
The PCB is in production, It looks something like this.
After testing I'll share BoM & all Gerber files.
As far as "noise levels of the original device", I just finished another one of these, it was built with AC heaters, connected it to a pair of KT120 mono blocks and it's dead silent with my ear to the speaker (RP600M). This was a point to point build, possibly trying to put this tube design on a PC board will end up noisy, especially if it's not laid out correctly. I've seen other PC board pre-amps that are noisy until they were converted to DC heaters. If you build this point to point and it's noisy, it's the layout or the lead dress, not the design.
Good stuff Eugene
I look forward to seeing how the PCB goes
Wayne
I'm not a fan of adding another coupling cap in the signal path, what noise are we trying to eliminate? And if someone does this, a 0.68uf is the smallest I would use, probably a 1uf would be better.
Thanks for the heads up Eugene. Following. Ron
