Getting to the end of my R8 mods. I made the changes is a bit of a different order. At some point I changed speakers and I started noticing a low frequency hum when the amp is turned up, or using the preamp input at any volume. After reading up on forums and the books you recommended, I realized I never moved the heater wire for the pre-amp. That got rid of a lot of the remaining noise and hum. Still has some hum though, but I have to practicaly put ear in woofer.
For me the best sonic improvement was aplitting the voltage stabilizer tube into separate channels, as for some reason my left and righ channels were out of phase, but after completing this mode, the channels were in phase on the oscilloscope and made a noticeable sounds stage improvement. Not sure if I broke something along the way, and fixed it, or if amp was always like that. Next best improvement was adjusting the negative feedback. I left the 33k resisors in, but bypassed them with 120pf silver mica caps, which resulted in slightly rounded off 1k square wave and pretty good up till 10k, severe rounding at 20k square wave, but 20khz sine wave is barely reduced in amplitude. It sounds now so good. The brightness that was fatiguing to me on this amp and my speakers are gone.
I published before I was ready.
Thank you so much for doing this series. This was a great introduction to tube amps, not sure you like rebuilding these inexpensive amps, but please know that you gave joy to many people who followed along. Thank you.
Going to continue to read the books you recommended, specifically "Vacuum tube amplifier basics",by Ej Jerich. Then decide on which of your projects to tackle next. Thinking phono pre amp or one of the simpler home brew amps.
Thanks again!
