Hey there! I’ve heard a bit about hillbilly mushrooms and hillbilly magic mushrooms recently. From what I understand, these terms often refer to a specific type of psychedelic mushroom that grows in rural or wild areas. They are commonly known for their strong potency and unique effects, often tied to a particular strain of Psilocybe mushrooms. The name "hillbilly" seems to have come from the idea of them growing in more secluded, countryside locations.
Some users report intense trips and vivid experiences, though it's important to always be careful when foraging or experimenting with wild mushrooms. The effects can vary greatly from person to person, so it’s crucial to know what you’re dealing with before considering anything. Just my two cents, always be safe and informed!
Anyone else tried them or heard more about this particular variety?
Like
Unknown member
Feb 20
Like
Unknown member
Feb 01
Looking to buy weed online in the UK safely and discreetly? Join our community to discuss trusted sources, share experiences, and find the best options for weed for sale in the UK. Whether you're a first-time buyer or a seasoned user, get tips on where to purchase quality weed online in the UK, learn about legal considerations, and connect with like-minded individuals.
Like
Unknown member
Jan 14
Want to leave a lasting impression? Google Review Cards are perfect for boosting trust. For something bold, Metal Business Cards are a sleek option. Prefer eco-friendly? Go for Wooden Business Cards or modern Bamboo Digital Business Cards. Need durability? PVC Business Cards have you covered. What’s your go-to style?
DescriptionTube power amplifier DIY handmade.Spare Tubes New available. Construction drawings and description available.This amplifier was made by a hobby builder and technician first class.I'm switching to monoblocks made by the same builder.All info except about the technique via marketplace.I only respond to serious interest.Payment by bank transfer or cash.Not a tap on apps and will not be sent for reasons you also know, weight and fragility.EL130 Power Amplifier DIY Description:The amplifier is equipped with 4 pieces of E130L power tubes that are parallel 2 by 2. These tubes are in class A at a supply voltage of approximately 170V. The power tubes are connected to a special stereo output transformer. This actually consists of 2 single ended transformers, but they are wound on the same core.Each channel also has a single E80F as a steerer tube.The steering tubes are controlled from a filter print.The filter ensures that the low tones of both the left and right channels are combined and sent to both control tubes. The mid and high tones of each channel are sent only to the corresponding channel. For the low tones, however, the amplifier functions as a mono bass amplifier, with the transformer in fact acting as a balance transformer. For the middle and high tones as a stereo amplifier, with the transformer in fact as 2 single ended transformers.The power supply consists of 2 toroidal transformers for the high voltage and 2 toroidal transformers for the filament voltage of the power tubes.The filaments of the control tubes are supplied with direct current and form part of the cathode resistors of the power tubes.The amplifier supplies a maximum of 20W per channel for the middle and high signal. For the bass, the amplifier delivers a maximum of 2x25W (50W mono).The bandwidth (-3dB) runs from 20Hz to 50kHz. The distortion is <0.5% anywhere between 30Hz and 20kHz.The outputs of the amplifier are switched on with a delay to block start-up sounds.
Clearly based on the E130L pentode. I think it's either a kit or a home build by somebody very knowledgeable and capable. I don't think I've ever seen a commercially made E130L amp. Likely the seller doesn't have a clue about it, maybe a deceased estate sale, who knows. If you take it on, you may have a whole lot of sorting to do. But I bet it could be a very worthwhile project for somebody.
Thanks for your reply. Can you help me sort this out? I love the building style so clean and without prints. Thank you so far. Maybe you can guide me in buying this or not. Leon
While it looks nicely built, the fact that none of the power supply cabling has been twisted is somewhat surprising.
It's not an amplifier that would interest me, but it probably sounds very good. All the info is there for you to make a decision!
Description Tube power amplifier DIY handmade. Spare Tubes New available. Construction drawings and description available. This amplifier was made by a hobby builder and technician first class. I'm switching to monoblocks made by the same builder. All info except about the technique via marketplace. I only respond to serious interest. Payment by bank transfer or cash. Not a tap on apps and will not be sent for reasons you also know, weight and fragility. EL130 Power Amplifier DIY Description: The amplifier is equipped with 4 pieces of E130L power tubes that are parallel 2 by 2. These tubes are in class A at a supply voltage of approximately 170V. The power tubes are connected to a special stereo output transformer. This actually consists of 2 single ended transformers, but they are wound on the same core. Each channel also has a single E80F as a steerer tube. The steering tubes are controlled from a filter print. The filter ensures that the low tones of both the left and right channels are combined and sent to both control tubes. The mid and high tones of each channel are sent only to the corresponding channel. For the low tones, however, the amplifier functions as a mono bass amplifier, with the transformer in fact acting as a balance transformer. For the middle and high tones as a stereo amplifier, with the transformer in fact as 2 single ended transformers. The power supply consists of 2 toroidal transformers for the high voltage and 2 toroidal transformers for the filament voltage of the power tubes. The filaments of the control tubes are supplied with direct current and form part of the cathode resistors of the power tubes. The amplifier supplies a maximum of 20W per channel for the middle and high signal. For the bass, the amplifier delivers a maximum of 2x25W (50W mono). The bandwidth (-3dB) runs from 20Hz to 50kHz. The distortion is <0.5% anywhere between 30Hz and 20kHz. The outputs of the amplifier are switched on with a delay to block start-up sounds.
