This is a great circuit! I played around with the power supply and designed a PCB, mostly as an experiment. Did a quick plate build. Call it a proof of concept as I want to tweak case work and plate. Maybe even add remote with an R2R arduino volume control. Possibly try a tube rectified/regulated (glow tube) supply.
Anyways the color pre sounds amazing. It takes a slight edge off my KT88 push pull monoblocks. I run an EAR 834 clone through the color preamp as well. Maybe redundant in some sense, but it doesnt hurt. The meters actually helped with cartridge alignment and 1 khz test record. Tons of gain....
The pots on input are a good idea, especially with the inherent drive of the 834 clone. The real win with the preamp is streaming.
Happy to share the PCB files. The layout isnt perfect, but the results work well for me. YMMV as to my ideas on power supply. That said, I built a board out for the basement, no choke and 12V 4A laptop power supply feeding boost converter for HV.
Hi ! stumbled upon this by chance while looking for other information, your post makes me curious: what is this "color preamp" for? It's an active volume control, OK, which is interesting in my case. If I understand correctly, it has a preamplification function, which can complement an RIAA EQ, but it is not an RIAA preamplifier? A kind of tube enhancer ? Could you explain why it seems to you redondant to plug it with EAR 834 clone ? Thanks you !
300V boost converter for HV. 12V laptop supply at 4A with LM7806 regulator feeding heater supply filter caps.
